RCC Column Minimum Reinforcement ???
I am designing a RCC column and under the loading (moment +axial) 250mmx250mm size of column is enough but due to the anchor bolt concrete cover requirements I need to increase the column size 750mmx750mm so my question is that I need to place the minimum area of reinforcement in the column according to the 250mmx250mm or 750mmx750mm.
If I follow 750x750 the minimum area of steel bar (1% x Ag) will be too much, so any one can provide the better solution in this regard???
thanks in advance
thanks in advance
RE: RCC Column Minimum Reinforcement ???
hokie - do you really use .5%? All the OG's trained us to stick with 1%. They only let us use .5% for lightly loaded pedestals.
"It is imperative Cunth doesn't get his hands on those codes."
Yes. Not sure of the OP's code, but some do allow 0.5 percent of the oversized section.
Dik
Mike McCann, PE, SE (WA)
