Need suggestion For Peek 3D-printer.
I want to print a medical tool with Peek filament. Do you have any suggestion for an affordable 3d printer that prints Peek with good accuracy (I want to print a hole with 1mm diameter)?
Thank you in advance.
RE: Need suggestion For Peek 3D-printer.
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
Here are our recommendations - which should act as a good starting point for you and your particular set-up.
Extruder Temps: 360 - 390°C
Bed Temps: 110 - 120°C
Bed Prep: Ultem® PEI tape or sheet
Spout Height: Minimal separation amongst spout and construct surface (squeeze first layer straightforwardly into the assemble surface)
Expulsion Multiplier: 1.0
Expulsion Speed: 1000mm/min (gradual wins the day)
Carbon fiber is more rough than unfilled materials, so broadened utilize will bring about more wear on your spout.
Cautioning: PEEK tends to stick to metal (PEEK cherishes metal). So make a point to cleanse out your extruder before it chills off or you run the hazard lasting stops up. Truly - we know this direct.
