Patran Nastran: No Result File was selected. No .xdb file.
I have a problem with Patran, when I try to access results, attach xdb, it appears the message: No Results File was selected and the Results File laryng-modes.xdb for job laryng-modes does not exist. Please select an existing Results File..
From the .f06 file I found this:
14 BEGIN BULK
*** USER FATAL MESSAGE 108 (SCA.MDSolver.Obj.InputFile.InputFile::read)
The input stream data file C:\Users\Fujitsu\Desktop\οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½οΏ½\laryng\laryng.bdf does not exist.
*** USER WARNING MESSAGE 209 (SCA.MDSolver.Io.AccessAccess.AccessAccess::isEchoSortRequested)
No stream input file has been converted to its binary form using StreamToBinary.
The ECHO data returns will all be false.
*** SYSTEM FATAL MESSAGE 501 (SCA.MDSolver.Io.AccessAccess.AccessDatabase::open)
Error 1 occured while attempting to open database ./laryng.IFPDAT.
*** SYSTEM FATAL MESSAGE 3001 (IFPDR)
THE INPUT DATA BLOCK NAMED IFPFLAG AT POSITION 1 DOES NOT EXIST.
USER INFORMATION: THIS ERROR IS CAUSED BY ONE OF THE FOLLOWING:
1. THE DATA BLOCK WAS NEVER CREATED.
2. THE DATA BLOCK WAS DELETED.
3. THE DATA BLOCK IS SPECIFIED ON A TYPE STATEMENT IN THE CURRENT SUBDMAP OR A HIGHER SUBDMAP
BUT THE CURRENT QUALIFIER VALUES DO NOT MATCH
Does anyone know, how can I solve this?
