Welding beads not visible in parent assembly
I have created a fillet Weld in an subassembly but I can not see it in the assembly which contains this subassembly. Do I need to check some option to see it?
RE: Welding beads not visible in parent assembly
Check that they are not excluded in the reference set you use.
I can't see it even if I make work part the assembly that contains the welding operation. The only way I can see the welding is by making it displayed part.
