Effect of low silicon content in A732 IC1020 cast steel
We have some parts made of A732 IC1020 cast steel, however, the silicon content is less than the 0.20% minimum, actual content is about 0.10%.
Can anyone advise if this is going to have any significant effect on the properties of the casting?
Thank you.
Thank you.
RE: Effect of low silicon content in A732 IC1020 cast steel
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
