duplicating contact paris between models in WB
I am trying to do a submodelling analysis, the submodel is a section of the original model that has a few contact pairs, and each time I do a new submodel analysis, I have to manually setup all the contacts from scratch. Not only this is a time consuming task, I am pretty sure there are alot of errors and differences in contact pairs between the models (the contact pairs needs to stay the same for all models).
Is there a way to copy contact paris between models that share the same geometry in the contact area?
Thanks.
