Any way to use something like "View Configurations" that changes constraints/position?
I'm trying to create a draft that shows an assembly's center of gravity, and how it moves when the part is tilted in multiple directions.
I'd like to be able to land all of them on one sheet, from the same model. View Configs don't save the change in constraints however. Is there any way to achieve this?
RE: Any way to use something like "View Configurations" that changes constraints/position?
I think that's the functionality you're looking for. In this case, it would be easier for you to read the help file regarding that process than to try to explain it via these forums.
If that doesn't work, then you may need to create separate assembly files. When you create the drawing view (on a single draft file) of each assembly, you should be able to create alignments between the views and the view centers lined up.
--Scott
www.wertel.pro
Am I correct that you can only change off-sets between positions this way? If I wanted to make some pretty drastic changes, then it seems like this won't work?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
