Load Sharing Ratio Between Retaining Wall and Basement Wall
Hello everyone,
We are aware that there are lots of theories to calculate earth pressure on basement walls. I will not go into that.
Lets say we calculated that load on the basement wall is F. Now, for example, we have a retaining wall too, in order to excavate to depth of foundation. For a diaphragm wall or pile wall, we know that even we consider 2 years service life for temporary structure, they will continiue to act as a rigid system, especially if space between retaining and basement wall is filled with good quality material.
My question is that: Don't you think it is overly conservative to not include the effect of temporary retaining systems on soil pressures on basement wall?
For example, I am sure that something like 30% of soil pressure will be compensated by retaining wall, if the empty space between basement wall and retaining wall is filled.
Do you know any work on this subject? What do you do, do you just ignore the effect of retaining wall?
Regards.
B.D.
Regards.
B.D.
RE: Load Sharing Ratio Between Retaining Wall and Basement Wall
www.PeirceEngineering.com
But I will look into it, maybe a research idea.
Of course, I considered this for pile and diaphragm walls.
