refresh loop on a rule that calls an action
Hello
can anyone please explain to me why this rule has infinitive refresh problem?
CODE -->
Let OpenBodyFeature1 (OpenBodyFeature)
Let OpenBodyFeature2 (OpenBodyFeature)
Let OpenBodyFeature3 (OpenBodyFeature)
Let OpenBodyFeature4 (OpenBodyFeature)
set OpenBodyFeature1 = `Geometrija izvoda\NN_strana\NN_gore_unutarnji`
set OpenBodyFeature2 = `Geometrija izvoda\NN_strana\NN_gore_vanjski`
set OpenBodyFeature3 = `Geometrija izvoda\NN_strana\NN_dolje_unutarnji`
set OpenBodyFeature4 = `Geometrija izvoda\NN_strana\NN_dolje_vanjski`
if Dvije_sekcije == "DA"
	Relations\Rules\Izvodi\Promijeni_status_aktivacije   ->Run(OpenBodyFeature1 ,true)
	Relations\Rules\Izvodi\Promijeni_status_aktivacije  ->Run(OpenBodyFeature2 ,true)
	Relations\Rules\Izvodi\Promijeni_status_aktivacije  ->Run(OpenBodyFeature3 ,true)
	Relations\Rules\Izvodi\Promijeni_status_aktivacije  ->Run(OpenBodyFeature4 ,true)
else
	Relations\Rules\Izvodi\Promijeni_status_aktivacije   ->Run(OpenBodyFeature1 ,false)
	Relations\Rules\Izvodi\Promijeni_status_aktivacije  ->Run(OpenBodyFeature2 ,false)
	Relations\Rules\Izvodi\Promijeni_status_aktivacije  ->Run(OpenBodyFeature3 ,false)
        Relations\Rules\Izvodi\Promijeni_status_aktivacije  ->Run(OpenBodyFeature4 ,false)
Relations\Rules\Izvodi\Promijeni_status_aktivacije is an action:
inputs:
CODE -->
geoSet :  OpenBodyFeature,visState :  Boolean
CODE -->
let GF_Children (List)
let SK_Children (List)
Let GeometricFeature1 (GeometricFeature)
Let Sketch1 (Sketch)
GF_Children = geoSet ->Query("GeometricFeature","")
SK_Children = geoSet ->Query("Sketch","")
for GeometricFeature1 inside GF_Children
	GeometricFeature1.Activity = visState
for Sketch1 inside SK_Children
	Sketch1.Activity = visState
RE: refresh loop on a rule that calls an action
i have the feeling that when you change the value to YES it trigger the action as something in the file changed. also when you change the activity to yes or no you trigger another action as something changed...
you might need to create a parameter flag and set proper value to run your action only once.
maybe something like
CODE --> code
if Dvije_sekcije == "DA" and runOnceFlag
	runOnceFlag = False
	runOnceFlag = True
else
	runOnceFlag = False
	runOnceFlag = True
Eric N.
