Combining two circuits in PLS-CADD
I have two separate PLS-CADD files with two circuits modeled separately.
The two circuits are strung on one double circuit tower.
What is an easy way to combine the two PLS-CADD files, such that the conductor stringing is maintained?
RE: Combining two circuits in PLS-CADD
Reply back if that works.
_____________________________________
I have been called "A storehouse of worthless information" many times.
Depending on how long is your line and how many sections you have, it might be faster to simply string the second circuit from the scratch.
When you are done you will have both circuits on the towers/poles. If you have LIDAR points of the existing wire, you can adjust the sag to match the points.
