ASME B31.3 APPENDIX V
Good day,
I am currently developing a pipe system design that needs to be aligned to ASME B31.3 code. As this pipe line will be under high temperature (1200F), I need to use the APPENDIX V (Allowable variations in elevated temperature service), which uses the Linear Life Fraction Rule to get the rupture life and usage factor, however I have a few doubts regarding this method:
-What does exactly the usage factor represents?
- is there any equation that gave us 0.5% or 1% creep strain time besides rupture life time? (The equation that is included in the standard for rupture life is tri=10^a, where a depends of the Larson miller parameter)
Thanks in advance!
Thanks in advance!
RE: ASME B31.3 APPENDIX V
Answer to second question- Don't know exactly. But I think you need to use creep power law equations. You can refer any textbooks on the creep design. I guess code gives life in terms of time-day/hour and not in terms of strain rate.
