NX Face Selection Intent Rules
3
Hello!
I wonder if anybody can explain why do we need the Region Faces selection rule? Which kind of faces this rule is suitable for? Thanks in advanced.
www.CADabout.ru
RE: NX Face Selection Intent Rules
Think about a painting job face selection. First select a required face and then select the boundary faces where you put masking tape.
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V10.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Hello, MFDO
Could you please provide a pic to illustrate it? Just can't wrap my head around.
www.CADabout.ru
@MFDO,
I like the painting analogy, that's a good one.
@Lockdain,
Imagine a complex casting made up of dozens of faces that are not tangent and don't belong to the same feature. If you want to select all the interior faces for some operation, the "region" face option allows you to collect all the faces in a few picks. The "tangent" or "feature" face rules wouldn't get them all and the "single" rule would be tedious. Attached is a very simple example in NX 9. I used the "region faces" of the "extract geometry" command to extract all the interior faces of the model.
http://files.engineering.com/getfile.aspx?folder=3...
www.nxjournaling.com
@cowski,
@MFDO,
I appreciate your help and such a good instances. Now it is clear for me bigsmile
www.CADabout.ru
