CATIA termination issue
Hi Folks,
Once again i am back with the CATIA termination issue.i have attached the abend trace file here.please let me know if you have any clue to it.the error says " click ok to terminate".i have attached the abend here.
RE: CATIA termination issue
What you attached is the error log file not the abendtrace file. Please check the picture attached.
Zou can take also a look at that file and try to understand, Eric is right, the Dassualt support knows better then anyone to what to look (but again, you are using a version which is not supported anymore).
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Thanks a lot for your reply.
