Radiator Cooler Design
Greetings!
I will be designing a cooling system for multiple engines.
I wan't to have the jacket cooling water be cooled using a RADIATOR COOLER.
The problem is I have a hard time finding reference resources on the internet.
Please help me find this resources.
This cooling system is for a 10MW Diesel Engine Power Plant.
Thanks in Advance.
Thanks in Advance.
RE: Radiator Cooler Design
The radiator manufacturer should be able to tell you how big you need to size it depending on the temperatures and location.
"Formal education is a weapon, whose effect depends on who holds it in his hands and at whom it is aimed." ~ Joseph Stalin
I.e., just buy a bunch of the typical Diesel generator skids sold in the oil patch.
Include remote monitoring and controls to link up to your fixed operator station, or a
control/supervisory skid.
You don't have to 'design' a cooling system; the engine/generator supplier can take care of it for you, and you don't have to worry about water distribution in huge manifolds. All you really have to worry about is installing the skids with enough clearance between them so the radiator airflows don't interact in a bad way.
Mike Halloran
Pembroke Pines, FL, USA
je suis charlie
http://www.superchevy.com/how-to/project-cars/sucp...
But basically you need to know the BTU, which is approx 43BTU per HP. Roughly 1/3 of the heat generated goes to the cooling system in petrol engines, less in diesels, but if you work on 15BTU per HP as an estimate then you can calculater the cooling core area required for the BTU output.
10MW is approx 13,500HP x 43 = 580500BTU /3 = 193500BTU to cool.
Thin radiators are better than thick ones, water & air velocity through the radiator will have an impact on the efficiency, as will the ambient temperature. A good rule of thumb is a radiator is the correct size, when the engine is at full load & the temperature drop across the radiator is 10+ degrees Celcius. By that I mean the coolant leaves the engine at say a nominal 80c & passes through the rads & arrives back at the engine below 70c, at the highest ambient air temperature expected. If at a steady full load state this is achieved then the radiator is the correct size for the application.
YMMV
