Roof wind pressures in long walkways (Components and Cladding)
Hi I am trying to determine which Net pressure coefficients should I find for a walkway (open bldg.).
The height is 10 ft and the Length is 250 ft long and width 10 ft, flat roof walkway. (h/L=10/250 = 0.04) The ASCE 7-10 provides a table for open roofs Fig. 30.8.-1 but it has a limitation only for those roofs that are between 0.25<h=0.04< 1. This excludes walk ways apparently. Wind tunnel is expensive and will not be applied to cheap structures like walkways. What is the best approach to determine the wind pressures in components and cladding for the roof?
RE: Roof wind pressures in long walkways (Components and Cladding)
