Check out the New ETABS 2016 Release Note!!! Great improvements!!!
Lock at the new features of the ETABS 2016:
Release note here:
https://www.csiamerica.com/products/etabs/releases
MSc. Eng. Serguei Joa
Structural Engineer
Bouygues Batiment International, Cuba.
RE: Check out the New ETABS 2016 Release Note!!! Great improvements!!!
1) An enhancement has been made to increase efficiency of creation of area meshes between analysis runs by saving them. Saved meshes are deleted on a story-by-story basis if changes are made that would affect the mesh.
2) An enhancement has been made to the design output table "Shear Wall Pier Summary" by adding several new columns to report the values of compressive stress, compressive stress limit, neutral axis depth (c), and neutral-axis depth limit (climit) for the following design codes: ACI 318-14, ACI 318-11, ACI 318-08, ACI 530-11, AS 3600-09, CSA A23.3-14, CSA A23.3-04, Eurocode 2-2004, KBC 2009, Mexican RCDF 2004, and NZS 101:2006.
3) An enhancement was made to add tool buttons to the "View" toolbar to toggle visibility of joints, frames, areas, links, and tendons in the active window.
