Input torque and speed for 1 KW generator.
How to calculate input torque and speed, i want to generate 1 kw of power. I am design a pneumatic motor to drive generator.
and also if speed of input pneumatic motor varies +-300rpm
Suyog Patil
CAD Enginer
NX 7.5. 8, 8.5 9, 10 TC-9
RE: Input torque and speed for 1 KW generator.
n is, of course, 1500 RPM. But you need to use the rad/s speed to find torque. So w = 1500*2*PI/60=157 rad/s
Torque needed is then power/w=1000/157=6.37 Nm
If efficiency is 80 percent, you need to increase torque to 6.37/0.80=7.96, say 8.0 Nm
To guarantee full output at lowest speed you need to use 1500 - 300 RPM. That will increase needed torque correspondingly.
w=126 rad/s torque at 100 % efficiency = 7.96 Nm and, at 80 %, 7,96/0.80=9.95, which is very close to 10 Nm.
The voltage regulation is not your problem, but should not be forgotten. It should also be noted that a PM generator plus an inverter probably is the best way to produce a stable AC or three-phase system from the variable generator output. If your output shall be DC - well, there are several ways to skin that cat also.
Gunnar Englund
www.gke.org
I guess you deal with 50 HZ .
So ,4 pole , 1500 RPM motor , 1250 KW motor shall generate a torque of 6631 N-m torque and will be suited for generating a 1000 eKW.
+/- 300 RPM shall mean that the generator frequency shall be 40HZ @ 1200 RPM (-300 RPM)( thus your generator breaker may trip due to under frequency ) and shall be 60 HZ(+300 RPM) @ 1800 RPM. This time generator breaker may trip due to over frequency.
How are you making air?
Get the electricity closer to the source of power.
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
