NX Edge blend Update
Dear NX Users,
Me and my colleague are working on powertrain components for Mercedes Benz since we are the supplier . We have designed a bumper model in NX which has a lot of edge blends. Based on FEM results it needs to be modified bascially we Need to re-postion some ribs again. The Moment it is re-positioned comes the error edge blend. It's pretty clear that nearby edges needs to be modified since some edges are missing but apparently in this case we need to modify all the edge blends because while designing tangent curves was taken into account. There are some 1500 edge blends which we Need to modify step by step. We had a GTAC technical Support in house but unfortunately no success. There should be definitely some tips or tricks to work on edge blend with NX because every single edge blend modification consumes a lot of time. Thanks in advance for your comments and Feedback.
