Toggle Leader Button for Notes
I use this just enough to make it annoying. I want to attach a note to a particular place on the drawing (mostly CL symbol) and then I want to remove the leader without having to close the Note Manager.
Right now, I must place the note, close the Manager (because the No Leader button is grayed out), click on the note to reopen the Manager and click on the No Leader button.
I know I could make a block, but this doesn't help with other notes I occasionally need to attach or I could click on the arrow and hit delete, but I just want to be able to toggle the leader on and off.
Does anyone know how to do this?
Thanks, Sylvia
Thanks, Sylvia
RE: Toggle Leader Button for Notes
I can turn off the leader.
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
I can also, turn off the leader AFTER I close the note and reopen it. Otherwise, the No Leader button is grayed out when I initially attach the note. Sylvia
There are no tool buttons or keyboard shortcuts to activate this, it's only available in the Feature Manager.
I've also tried Favorites and the Design Library. Neither achieves the goal.
Thanks for responding, Sylvia
