Stiffener and Doubler Plates
Hi guys,
What is the difference between Stiffener and Doubler plates? Doesnt both serve the same purposes?
RE: Stiffener and Doubler Plates
Stiffeners and doublers can do a lot of things depending on the situation. And there is some overlap. Here's a basic summary of the obvious stuff.
Stiffeners
Stiffeners take concentrated loads applied to the flanges and distribute them nice and smoothly across the web. This helps with failure modes such as web yielding and web crippling.
Doublers
Doublers increase the shear capacity of the web. They do this by adding additional shear and improving web shear buckling strength.
Stiffener plates act in tension or compression whereas doubler plates act in shear.
BA
