Plywood bracing roof beams?
It is my understanding plywood is usually nailed to wooden roof beams at some spacing. When checking the roof beams for bending using NDS provisions, is it OK to assume that the plywood braces the beams at the nail spacing? I am referring to lu in NDS 12, table 3.3.3.
RE: Plywood bracing roof beams?
