weld neck flange
weld neck flange
weld neck flange
dear all
please help, anyone have the dimension of weld neck flange PN100 1 1/4" based on din 2637 ? its only mention in DN En 1092-1.
Can i use the both standard, example ;
PN100 1/2 inch--> use Din 2637
PN100 1 1/4 inch --> use DIN en 1092-1
Thank you very much
RE: weld neck flange
You might try the Pipelines, Piping and Fluid Mechanics engineering subforum or the Boiler and Pressure Vessel engineering subforum.
Flange suppliers in a country that uses DIN standards may be of help.
