Torque Testing
Torque Testing
We are torquing down bolt at between 48 to 54 ft. lbs. If we are consistly getting 50 - 52 what should the breaking point be when we test them? We are also auditing torque angle. I believe that is set between 10-30 degreees.
RE: Torque Testing
Typically, structural engineers shy away from torque calibration of bolts because in our world it tends to not be very consistent.
RE: Torque Testing
Steel-GMW25 (Class 0.9) zinc plated
There are 20 bolts to bolt together the attached assembly used in a transmission.
Includes 3 flexplates, 1 flexplate asy., hub, wearplate and shim
