Journal/Sleeve Bearing Clearance
How do equipment manufacturers determine the journal bearing clearances for their pumps, compressors, etc.?
Is there a rule-of-thumb for determining the optimal bearing clearances (metric)?
Do manufacturers use 'hyper-theoretical' means of determining these clearances? By this, I mean, do they use the fundamentals of hydrodynamics to determine the required shaft supporting force to ascertain what the correct clearances should be?
RE: Journal/Sleeve Bearing Clearance
A typical value is 0.001 of the shaft diameter.
But this can vary widely depending on:
- application: passenger cars will have less clearance, heavy power pumps will have larger clearance.
- oil used & oil temperature
- rotational speed & load
And yes, journal bearing manufacturers calculate this for you, usually using extended reynolds equations
The July / August edition of Plant Engineering magazine (http://www.plantengineering.com/magazine.html) has an article about this topic starting on page 47.
http://bt.e-ditionsbyfry.com/publication/?i=328277#{"issue_id":328277,"page":0}
The design of radial journal bearings used on machinery like pumps and compressors can be quite complex. It can involve fluid mechanics, heat transfer, shaft dynamics, metallurgy, chemistry, etc. I doubt any legit OEM would be foolish enough to market a piece of machinery with journal bearings that were designed based on a "rule-of-thumb".
Here is an excellent public source technical reference that covers the basics of journal bearing design. Definitely worth a read.
Depending on the speed of the plain bearing, lubricant type and delivery, and expected bearing life, hydrodynamic lubrication is not necessarily present. In cases of mixed-mode lubrication, plain bearings can operate very well and the designs will be based on rule-of-thumb and existing design references win the day. I was once involved in a dispute about a plain bearing design and it was very challenging to agree on best practices for design.
One major factor in clearance selection is angular misalignment - long thin shafts are not favorable for plain bearings and require more clearance.
