Granite Memorial Anchoring
I just got tasked with designing foundations for a new memorial park. There are a variety of granite benches, posts, plaques, etc. The issue that I am currently having is determining the best way to anchor an 8' Tall x 1'-6" Wide x 8" thick piece of granite. My initial thought is to use something like Hilti to epoxy in dowels to the granite and concrete pier of the foundation. Since the granite is only 8" thick though, I have concerns about how deep I can dowel into it.
Any ideas or references would be greatly appreciated.
Thanks!
Thanks!
RE: Granite Memorial Anchoring
I don't know if you are going to find any references (I could be wrong), but I would recommend working closely with the granite supplier. It would be much more advantageous for them to do any drilling/modifying of the granite in the shop then letting it be field drilled. Also, depending on the situation, you may want to use SS anchors to reduce the amount of rust staining.
Sounds like a cool project! I did one a few years back for the local VFW. Those vets sure don't get enough credit for their sacrifices!
I attached the sketch for the area in question that the Landscape Architect provided me. After talking with them a little more closely this morning, they have agreed to have the granite supplier do the drilling and at this point just want the dowel anchors spec'd out with total embedments, epoxy, etc. The printer/scanner at the office is down right now, so I am unable to upload my hand sketch, but I was thinking just a basic concrete spread footing with a 2' pier and 3 - 24" dowels extending 12" into the center of the granite and 12" into the pier.
Then use Hilti HIT HY 200 adhesive to secure to the foundation below.
thread507-308460: Anchorage of Granite Base
"It is imperative Cunth doesn't get his hands on those codes."
Dik
