Exploded views
Exploded views
Hi everyone,
I'm using NX10 and have set up some exploded views within my drawing file.
I have created my exploded views and placed them onto the drawing. When I make a change to the explosion and saved the view. I then go into the drawing mode and use update view, but it does not update to what I have modified. I can delete the view and put it back in and then it's correct.
I have named the explosion with the same name as the saved view as I was told this is a good practice.
How can I get the view to update without having to delete it and put it back in? What am I missing here?
RE: Exploded views
You should not need to save the view after editing the explosion. Perhaps you are inadvertently saving a new view after your edit, which leaves the original in its unedited state - that would explain why it is not updating.
Here's my procedure for creating/editing exploded views:
www.nxjournaling.com
RE: Exploded views
I have been doing the same as you explained. I have been saving the view after any modifications to the explosion, but not as a new view.
I actually had the views update okay since I posted. I normally switch views using the Part navigator under model views and not replace view.
Not sure if that makes a difference, but I will pay close attention on what you have provided to me. Thanks again.
RE: Exploded views
I have modified the explosion by using Hide components in view and turned off items I did not want to see.
When I go back to the drawing and update view these items are still there after the update view.
Is this something within the view settings that needs to change?
RE: Exploded views
Then update the view & the unwanted components should be removed from the view.
RE: Exploded views
Thanks again.
RE: Exploded views
