Volume in real time
Volume in real time
Is there a tool or solution that can show me volume of solid in real time (without need to measure it every time again and again)? For example it update after i change value for expression that will modify solid in some way.
_____________________________
Enjoy your work and have fun!
RE: Volume in real time
Note the new features should be before the body measurement!
kukelyk
Tomas
then do some change on the model before the measurement . The displayed measurment will update.
If you like, you can under Preferences - Modeling - Update- Dynamic update = Continous ( or incremental)
Note that the model should not be too heavy for this to perform well.
In case you need the model volume be a target value , you can run the Optimization feature.
Tomas
kukelyk
