how to make the "hole chart" visible??
Dear all,
we want to add a hole chart with ISO pass through holes with counterbore slots for heads and washers.
We placed the attached hole chart in the mounting points, but we can not get it to be visualized..
for sure there is a missing trick, but I do not find specific indications around..
with regards,
Edo777
with regards,
Edo777
RE: how to make the "hole chart" visible??
did you wanted to do the same, dgallup?
Did you had a short name for your file names, or loose and long?
thanks in advance,
Edo
Ben Loosli
