oil droplets /water separator design
Hello all ,
I'm wondering if anyone have an idea how to design a separator that will be installed on a pit
after oil treatment unit for removing oil droplets from water ; the flow rate is 2 gallon/ min .
I have followed API 421 but it doesn't work for this small flow rate .
THANKS A LOT !
REGARDS !
RE: oil droplets /water separator design
Oil separators are typically purchased as an equipment item that is already designed and fabricated.
Link
I'm assuming you mean what is typically referred to as an "API separator", i.e. a long thin tank which is calculated to allow oil of a certain droplet size to migrate tot he surface for final skimming?
Most people nowadays, as bimr says, would buy a small pre-packaged unit or a tilting plate interceptor for such use. Far more compact and efficient.
Also API 421 separators nowadays often don't meet the discharge requirements.
