2-way slab punching shear at edge columns
I have a 2-way slab and am checking punching shear at the edge columns. The critical section at an edge column typically has 3 sides. How far past the edge face of the column must the slab cantilever before I can consider the punching shear critical section to wrap around all 4 sides of the column? (I can't find anything definitive in ACI 318 nor in the PCA notes that clarifies this.)
RE: 2-way slab punching shear at edge columns
I'd imagine it may be a case-by-case decision (informed by experience and maybe a helpful rule of thumb from one of our wiser members).
Some countries have code recommendations for this and some don't. I believe that Canada and Europe both have (or had) recommendations of five times the slab thickness beyond the column face. That said, rapt's method strikes me as eminently rational.
RAM Concept which I've used and ADAPT etc will do this as long as the programs are given proper inputs.
If you're hand-calcing, you need to run it a few ways. Consider not merely the perimeter lengths but also the slab-column moment (ACI 318 Fig R11.11.7.2), which will be somewhat increased by increasing cantilever distance. If you have a lot of conditions, a spreadsheet will be useful. Plus architects are known to shift slab edge dimensions.
