E7016 / ER 70S 6
E7016 / ER 70S 6
Dear Sirs,
I have material SA516-70N + S5 and MDMT -10 degree celcius which will be welded using E7016/ER70S-6 and WPS & PQR without impact test.
my question, is it possible to application?
if it is possible, kindly inform us for the references code.
Best Regards,
Bahruni
Best Regards,
Bahruni
RE: E7016 / ER 70S 6
Please advice.
BUT the welding consumes of E7016 and ER70S-6 have a good impact toughness characteristics, you can add a impact test using the same essential various of the origin PQR and then use a new WPS&PQR to weld the components.
