Setting Revision Rule in NX Load Option by VB
is there a possibility to set the revision rule in the NX Load-options bei a VB-code? We are using the revision rule "latest working" in Teamcenter as default. But we need a differend rule in NX as a default. So we would like to create a VB which can be run when NX will be started.
Can anyone help me?
Can anyone help me?
RE: Setting Revision Rule in NX Load Option by VB
