how specify name set or Code for dimensions in drafting and show it along values?
Hello
I have to place name or a code for dimensions along with their value in drafting. Is it possible in NX?
I won’t use append text or manually input one by one.
For example, a name set for linear dimensions and a set for radials and so on.
Like this:
LD01
LD02
LD03
And
RD01
RD02
RD03
I found that at bottom of information window, in Object Dependency Graph every dimension has an “ID code”. Can I view that code on drawing?
What about expression names? can they be viewed along with dimension value?
Windows 10
NX 10
