Modeling an already installed system
Hi all,
I have a some amount of experience using Caesar however I am not an expert by any means. I have a task to do which involves modeling an already installed pipe system and then seeing if the support system can handle a heavier component such as a valve.
Now my system is such that the piping is connected to a steam vessel (no thermal growths given by the vendor for this vessel) and then goes to a a 40 ft section on a pipe rack.
Now I have drawn out the system such that I anchored at the nozzle for now and went to the header however only to the first support along that header (otherwise I'd be modeling an entire piping run). I left this end with a +Y support as it's on a beam and has a guide support as well.
My main problem is that there is an already installed spring hanger. Using the program I let Caesar design the spring for me. Now the problem (if it is an actual problem) is that the spring hanger that was selected doesn't match what is on the installed spring's drawings. For example, CII selected a hanger with a spring constant of 1500 lb/in with a travel around -0.2 inches (cold load about 2500 lb) whilst what is actually on the drawing is a spring constant of 380 lb/in with a travel of about -0.7 inches (cold load around 4100 lb.). (This is modeling the system as actually installed). Now I am not sure as to if the original designer over designed or something.
Now I am pretty sure that my model is somewhat wrong as my springs don't match up. Can anyone assist me in my task or at least lend some advice on how to accomplish this ? I can upload the model if anyone is able to assist.
RE: Modeling an already installed system
Either:
1. The original analysis is incorrect
or
2. Your analysis is incorrect.
If you have only modelled the pipe from the anchor to the first support then it sounds like your model is insufficient for obtaining accurate results.
Post a sketch to let people provide a better assessment
Thanks for the reply. I have uploaded the drawings which I modelled from the anchor on the first sheet to the drawn in 10-20 ft length on the second sheet. I added in most of the details on the drawing as well for the supports.
One thing I believe I have done wrong from further research is that in C2 I put my spring variability as 25% whilst the spring has a 6% variability. So that may be the error there.
Another problem from the model is that the highest stressed points are where the trunnion supports join to the main pipe run (on the first page). The trunnions are made up of 30 inch long pipes. However since they aren't intersections, I am not sure if I need to model SIFs for them - One of the trunnions has a re-pad on them and a stiffener bar locaed within the trunnion. Not sure if I modelled this correctly or if I should manually find the second moment of area and then put a pipe which would have an equivalent second moment of area here.
EDIT: C2 file uploaded.
I did run with the additional SIF at the bottom trunnion however that just managed to fail the stress analysis while the spring being chosen was not the one installed. So C2 will suggest a spring with a constant of 761 lbf/in with a movement of -0.214 inches whilst the installed spring has a design of 380.5 lbf/in with a movement of -0.71 inches (i.e. long range spring).
I would not forget to model the nozzle movement on the steam vessel that you described. There must be some kind of movement there and it has to be included. The nozzle allowable is another to check on the analyses.
In the new model I would add the the intentional new valve and re-analyse the piping with the existing spring hanger to see the system working without problem. If there are problems with the systems then look for solutions such as replacing the spring hanger with the new selected by the software. Selection of the location of the new valve ( if not the same as original or with different weight and different dynamic behaviour) should be done intelligently, it will have impact on the stress analysis and the piping behaviour. It should satisfy the process engineer as well as the stress analysis.
The system I modeled would be the original set-up with the original valve. I was doing this to check the model for accuracy in terms of finding the hot load as indicated on the original hanger. Like you said, what I may need to do is model the vessel in C2.
Yeah I figured that I'd need to start over as I realized that I would need to model the vessel in C2 as the drawing for the vessel neither specified allowable nozzle loads or even the thermal growth associated with the vessel. However, I did initially model the line as given on all the isometrics.
If there is a problem, and the source of the problem is the spring hanger only let CAESAR II select the spring hanger for you. Sometimes with addition of new mass into the system you may require to add supports around the mass. If the nearest support is the spring hanger so you may change the spring hanger or add another one. These sometimes do not work as suggested, you may try many combinations of the trials to make it works, the trials include the relocation of valve and the change in to piping route.
Unfortunately, we cannot provide the magic answer, you need to work on it systematically, and sometimes take notes on your trials not to get in to endless cycle.
Hope it helps.
