Is there some portable equipment for measuring gas concentrations inside HT ovens?
Hello to everyone, I'm new to the community, so I apologizeif I do something wrong.
I'm in need of help, I want to know if there exists something that does the exact same thing as a O2 probe, for Heat Treatment ovens, but portable, that can pe used to check the procentages of each gas from the mixture.
Any help is apreciated!
Thank you.
RE: Is there some portable equipment for measuring gas concentrations inside HT ovens?
We use a portable three gas analyzer to verify readings that we are getting from our oxygen probes in our heat treatment ovens. The one we use is from Super Systems Inc., it seems to work fairly well for our needs. They have other options for gas analysis as well.
Here is an example of the current version of the one that we use:
http://www.supersystems.com/analyzers/pga3510/
Aidan McAllister
Metallurgical Engineer
Thank you very much!
