Nozzle design
Nozzle design
I have a request for a nozzle design that is located on the shell. It is oblong leaving the shell then has a transition (obround to circular) then a flange. Where do I look for the calculations to design this to ASME Section VIII Division 1? Thank you in advance for your help!
RE: Nozzle design
No specific rules for required thickness of the nozzle neck at the obround, it will be a U-2(g) calculation. Often avoided for this reason.
Mike
RE: Nozzle design
RE: Nozzle design
Mike
