Certain metals detectable by ground scan?
Hi all. I don't get by here much but I wanted to ask a question that I've been curious about, since my father inlaw has decided to move to Alaska to mine for gold. I'm no metallurgist, I am but a lowly engineering student that is still seeking my associates degree. But it does seem to me, with my limited knowledge of such things, that one should be able to at least tell what type of metal is under the ground (or laying on your shop floor) with a scan of some type.
For example, doesn't every metal give off a certain, measurable magnetic field? If so, wouldn't some instruments or scanners be able to pick that up, and then be able to tell you what type of metal was there? I was wondering, because the method he's using to try to get some of the gold seems... archaic at best. Simply letting water flow through a sieving machine, and collecting the particles. Well of course anyone who thinks about it, would realize that there are probably much larger sized chunks of gold, at various depths beneath the bottom of the river/stream that he is mining in. And the water is only 1 foot deep (or less) in some places.
Of course the trick is locating the larger chunks, as the river/stream is miles and miles long. Where do you dig? How deep? Is there some way to pick up the weak magnetic field that gold has? Or am I barking up the wrong tree here? I haven't gotten far in my engineering studies, but I remember hearing somewhere that all metals have a magnetic field which surrounds them, but of course this will vary from metal to metal. Thus, gold would have its own, and once you calibrated your equipment or had sensitive enough equipment, you may be able to tune it to detect only gold.
Is this possible? If not, how far off base am I?
RE: Certain metals detectable by ground scan?
>> No.
>> No. Where did you get that piece of erroneous information?
>> No. You are pretty far off base. Even if you knew nothing about the physics, do you really think that you're the only one that's ever asked this question? IF such methods existed, don't you think that every accessible location would have already been mined out and that your father would be completely wasting his time?
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Regardless, thanks ed for the helpful reply. Not so much to the other two. Must not actually be engineers.
Anyway Ed, it sounds like you're on the same line of thought I'm headed down. I wonder if the noise you speak of, could be filtered out in some form or fashion. They do have ground penetrating radar that yields some different colors on screen for different densities.
The other two are indeed engineers and valuable contributors to ET. I was the one that gave the purple star to ornerynorsk because of his wit.
Research "proton magnetometer". However, to be entirely practical, you may find yourself with a pan doing "stream surveys" after all. Some of the best minds on the planet have been on the case for the easy track to gold for centuries, and no magic solution has appeared.
Thanks metengr!
The benefit is that you get much better signals, but you can only 'see' a few inches.
Mining companies have truck mounted units that can penetrate a few feet.
The best method is still simply being able to identify minerals and follow the deposits.
Most other methods described above can detect differences in the materials, but not what specific materials they are, so you'd have to dig, which is expensive, compared to the potential return. In fact, even a GPR would likely have a poor ROI. Gold miners of the 1849 variety, when gold was more commonplace, seldom found even gold to pay for the services and goods they consume while they were mining for gold. Interestingly, most of them didn't actually "mine," they "panned" for the gold.
Others just placer mine whole areas, like the deposits in the road drains and the rock traps. The density difference between gold and other minerals is so large that it doesn't take much- just a big pump and a properly designed flume, and of course a shovel and having no care about flooding a stream with sediments. We tend to try not to do the latter when building stuff, so why it should be OK to disturb and re-entrain the sediments along the sides or bottoms of streams is beyond me.
I think you will find that a great many states now have laws in place to deter people from carrying out the activity you describe. I believe Alaska is one of the few states that allows it, as long as you do not mess up the salmon spawning grounds.
B.E.
You are judged not by what you know, but by what you can do.
Design for RELIABILITY, manufacturability, and maintainability
I don't know the current magnetic technology, but 50 years ago it was believed that ferromagnetism was the result of unbalance electron spin. Some years later, a non-metallurgist friend said that Aluminum (non-ferromagnetic metal)will become magnetic in a moving electrical field. I accepted this at the time because I know electric current produces a magnetic field but I don't understand how that works with a non-ferromagnetic metal.
Is it true that...
Aluminum (non-ferromagnetic metal)will become magnetic in a moving electrical field??
If so, what is the mechanism?
The result of these eddy currents is that they have a magnetic field associated with them (like all current flow does).
alternative systems require access to a thin sample: http://www.icdd.com/resources/axa/vol52/v52_23.pdf
http://www.eng.uc.edu/~beaucag/Classes/Analysis/Ch...
In either case, bulk testing of large quantities or areas is not feasible, and the depth of penetration of x-rays limits its ability to probe; for hydrocarbons, which have low absorptivity, optimum thicknesses are on the order of millimeters, which means that for metals and rocks, the thickness limit is even thinner.
People frequently use XRF on compacted powder samples.
All have a good weekend!
I think you would have more luck using a metal detector on the beach or anywhere frequented by tourists than you would in a river somewhere in Alaska where people have rarely or never been. In the former, you might find manufactured goods or coins that contain little if any gold, but are valuable. At least you would get a lot of hits to keep your interest. In the latter, you have to deal with your batteries performing poorly in cold, wet conditions, and any metal you detect, even if it is gold, still has to be found.
The point of panning in a river is that the gold is in the sediment in particulate format. Finding it with any kind of scanner doesn't help you separate it from the water.
Ed wrote "Any electrically conductive material will generate Eddy Currents when moved in a magnetic field.
The result of these eddy currents is that they have a magnetic field associated with them (like all current flow does)."
Gold is quite conductive. And don't they have to build special underground facilities to test certain equipment, when they need to get away from electromagnetic interference from say... radio stations and such? I remember that BMW has such a facility underground somewhere, so they can have a "dead zone" to test in. Well, if gold is highly conductive, and these EMF's will penetrate into the earth, and you can cause eddy currents, then couldn't you run and EMF into the ground, and have other equipment that was tuned to look for the eddy currents? Wouldn't those currents somehow be detectable from the surface?
FYI it wasn't me that is doing the mining. I just thought it was interesting because my father inlaw decided to go do alaska and start doing it.
Nathan Brink
