Radiography Test in PV Elite
Hi All Engineers and Designers,
I have one question to ask. It may a dumb question but I need an answer to learn more about PV Elite. In Datasheet of Pressure Vessel,for radiograhpy test it stated as SHELL: 10% SPOT + ALL 'T' JOINTS. I used code ASME Section VIII Div 1 and I dont know to input this data in PV Elite
RE: Radiography Test in PV Elite
Radiography of "T-joints" is unusual and would not normally be required.
Or so I would guess.
Mike
welded intersection, vessels made up of two or more courses shall have the centers of the welded longitudinal
joints of adjacent courses staggered or separated by a distance of at least five times the thickness of the thicker
plate.
r6155
r6155
