propeller shaft design
I have a three blade propeller. How do I calculate the radial forces on the propeller shaft bearings due to gyroscopic forces when turning. The prop will run at 3000 rpm and generate 500 lbs of thrust. each blade wieghs 5.5 lbs and is 28 in. long. the center of gravity of each blade is 8.4 in from the hub. I'm not sure what moment will be on the propeller shaft when in a turn. If you know of other important considerations, please advise. Thank you.
RE: propeller shaft design
Maybe this link will help you
http://naca.central.cranfield.ac.uk/results.php?Simplequery=stress+propeller&st=AND
Fernando
Hope I helped....
