Error when generating mesh
Hi
I got an error "a general failure occurred during the solution process" when I was trying to create mesh for my assembly. It's a complicated assembly so it's not surprising to get such warning. Anybody has a clue of how to fix it? I posted a screenshot below if it might help.
Thanks.
Thanks.
RE: Error when generating mesh
Either try to mesh all the bodies in the assembly one by one to at least eliminate the OK parts and understand which part is giving you problems, or if possible upload you geometry and we can try it ourselves and maybe give you some input.
