Multiset - dynamic analysis
I want to perform an dynamic analysis which is splited in more steps with different loads. Each step should succeed the previous starting from the reached deformation (without reseting the deformation state). This shoul work using multiple set in the Analysis Manager. The Problem is, the multiset button is not available (gray). Can anyone give me a hint please!
Thanks!
