WT4x7.5 A992 Tee Piping supports for ASME B31.3 Piping
Im looking to see if anybody has experience fabricating piping supports from A992 Ibeams/Tees. I say Ibeams or tees because i cant gather if fabricators take i beams and cut the flange off one end or order a tee that only has a flange on one end. I have a current bid to do where the drawing requests WT 4x7.5 A992 material but i cant seem to find this material online anywhere. Would anybody with pipe support fabrication experience please help me here.
CLoya14
CLoya14
RE: WT4x7.5 A992 Tee Piping supports for ASME B31.3 Piping
https://shop.ryerson.com/catalog/search/102120101
Any steel fabricator in your area can make these WT’s for you, as part of your order for the rest of the steel you need for this pipe support system.
