on embedded plate with stud bolt, we dont need to specify the welding of bolt to plate?
I'm looking at my go-by dwg, only the stud bolt dia and plate size are specified, the welding of stud bolt to plate is not.
Is this not necessary? In my case minimum welding size will work.
RE: on embedded plate with stud bolt, we dont need to specify the welding of bolt to plate?
