CATIA VBA : Get instance name path from selected item to root product
I have issue with getting instance name path of selected item to root product.
Result that I want to get from CATIA in this case is string with the following path: "Product2.1\Part2.1"
Additional thing is that CATIA tree will be not known in the future. Getting path formula should work with different multilevel trees.
Simple CATIA tree:
!Product1!
VBA Code:
Dim Sel1 As Object
Dim Filter1(0)
Dim Status1 As String
Dim objSelPrd1 As Product
' [ Part Selection ] ***
Set Sel1 = CATIA.ActiveDocument.Selection
Filter1(0) = "Product"
Status1 = Sel1.SelectElement2(Filter1, "SELECT PART", False)
' [ Switch Part to Design Mode ] ***
Set objSelPrd1 = Sel1.Item2(1).LeafProduct
objSelPrd1.ApplyWorkMode DESIGN_MODE
MsgBox Sel1.Item2(1).LeafProduct.Name 'gives result "Part2.1"
MsgBox Sel1.Item2(1).LeafProduct.Parent.Name 'gives result "Products"
MsgBox Sel1.Item2(1).LeafProduct.Parent.Parent.Name 'gives result "Product2.1" but I don't know how many levels CATIA tree will have in different products
So I'm searching for a solution to get whole path as string from Part chosen by user no matter of CATIA tree complexity - in this case "Product2.1\Part2.1"
Thanks in advance,
Michal
Simple CATIA tree:
!Product1!
+- Product2 (Product2.1)
+- Part1 (Part1.1)
+- Part1 (Part2.1) <- Selected Item by user
VBA Code:
Dim Sel1 As Object
Dim Filter1(0)
Thanks in advance,
Michal
RE: CATIA VBA : Get instance name path from selected item to root product
CODE --> vba
Sub catmain() Dim Sel1 As Object Dim Filter1(0) Dim Status1 As String Dim objPrd As Product ' [ Part Selection ] *** Set Sel1 = CATIA.ActiveDocument.Selection Filter1(0) = "Product" Status1 = Sel1.SelectElement2(Filter1, "SELECT PART", False) ' [ Switch Part to Design Mode ] *** Set objPrd = Sel1.Item2(1).LeafProduct fullpath = objPrd.Name While Not reachroot Set objPrd = objPrd.Parent fullpath = objPrd.Name & "\" & fullpath checkParent = "" On Error Resume Next checkParent = objPrd.Parent.FullName On Error GoTo 0 If checkParent = CATIA.ActiveDocument.Name Then reachroot = True Wend MsgBox fullpath End Subindocti discant et ament meminisse periti
When I try to use it as CATScript I get infinite loop. In other case when I try to use as VBA I was asked to add a few dims but even after that step I not received MsgBox, macro just stops/crash without it.
Dims that I added:
Dim fullpath As String
Dim reachroot As Variant
Dim checkParent As String
CODE --> VBA
Error msg:
Run-time error '13':
Type mismatch
CODE --> VBA
