Any experiences in sealing for large diameter body flange (>8ft) in a fluoropolymer lined vessel
Hi All
I am researching a new design for a separator in acid service (rules out 100% metallic construction) and am looking for some industry experience... Background:
- horizontal tank
- about 8ft diameter, 15ft long
- body flanged at one head (full tank diameter)
- there is a large baffle assembly inside that was installed through the one end
- once pack installed, vessel was brick lined.
- Operating pressure is low, around 10psig. Temperatures range from about 40F to maybe 110F
- process includes strong HCl acid
Basically the brick in the vessel is at end of life and there is debate on the new vessel design.
1. Glass lined steel is a good candidate except for the huge diameter body flange, which would seem to potentially be very difficult to seal, as flatness issues typically arise >3ft diameter. One way around that was a bafflepack design that can be installed in small pieces through a normal manway, but that will mean nearly impossible to inspect as getting it removed each time would be a huge safety risk (very difficult to clean, as the modular design seems to consists of numerous long, flat plates very close to each other) and time sink. Going with this nearly cements the fact we would not be able to inspect the entire vessel in the future. And designing a vessel knowingly that cannot be inspected doesn't feel right to me at all.
2. Plastic lined steel (vacuum bonded PVDF or PFA) is a good candidate as well; however I have no data on sealing a flange that large. I personally feel this is a good option, but would definitely want the ability to open the head, pull the pack, and 100% internally inspect, since plastic welds aren't quite as reliable as say a brick lined system.
3. Brick again, but we have serious issues cleaning it now (sticky materials, brick outgasses, etc...), and would require huge effort if we needed to change or move the baffle pack (unbrick and rebrick an entire head).
So, all that to say, does anyone have some experience/reliability with a large diameter plastic lined flange that they could share? Specifically on how easy/hard to get a good seal. I just don't have anything of comparable size so I can't comfortably make a strong case one way or the other. I've probably forgotten or mucked up some detail so please ask for any clarification on something, if needed. Thanks!
- horizontal tank
RE: Any experiences in sealing for large diameter body flange (>8ft) in a fluoropolymer lined vessel
Mike
Thanks for the reply. I am inclined to agree; with the vacuum bonding I would think the flatness of the steel flanges is the chief factor, whereas with glass the glass itself can have varying thickness, and the heat cycle can warp the flanges and vessel.
How large of flanges have you worked with? We also have experienced issues with spalling at the radius on the larger diameters. I probably should've included that in my first post.. sorry. That was an additional reason we have been steering away from glass (if we didn't have the spalling issues I think we would've already been sold on glass, however issues in on of the European plants with the aforementioned spalling has people on edge with that strategy).
Tom Haber
thaber@mas-mss.com
Maverick Applied Science
Large diameter glass lined steel (GLS) not a problem for expanded PTFE (ePTFE) tapes, I've seen even older 2m+ diameter vessel sealed no problems by it, just requires a careful installation. You can layer them up in local sections (known as shimming) to account for flange flatness issues, I'd suggest getting specific training for this its very useful. I've seen applications were 6mm thick ePTFE has been layered up 10 times (60mm of gasket, shimming up roughly a 30mm gap!), I obviously don't recommend that... but 3-4 times in a local area is easily done and quite commonly done with larger flanges (not just for GLS).
I'd send you a link to a good ePTFE tape made just for GLS as its requires less surface stress, but I work for the company that makes it; so I assume that's against the rules.
However if you spoke to De Dietrich they probably recommended the same thing anyway as they do on this webpage....
http://www.dedietrich.com/en/solutions-and-product...
As for the spalling, is this just on the flange facings or do you mean on the actual ID of the vessel? If near the flanges ensure your using a ePTFE tape that is wide enough to cover the whole flange face and a bit more into the rounded section. A good gasket should conform to the whole flange face, especially if it's rounded like in GLS applications. Some harder filled PTFE materials (and /or envelope gaskets) don't do this quite so well. The idea is to try and prevent a crevice or dead spot being formed in the vessel were local super concentrations can occur which could attack the surfaces.
Hope this helps.
Dan
We always try to get the wishbone shape - "overhanging" gasket on ID and OD to combat suck-in/blow-out. For the spalling, it seems to be more on the radius of the flange internal to the vessel. As I mentioned before, we've had lots of problems with that specifically from our European plant - and they use envelope gaskets. So it is a "lively" discussion when trying to recommend GLS for this project as they have lots of problems with it (whereas here in the USA we've don't see that radius spalling). Trying to convince them to move away from envelope gaskets is like pulling teeth, but we keep at it :)
Now just to make sure I and/or Gore would never recommend doing more than 3-4 shims, the 10x case was crazy... but it worked and from what I understand is still working... but please consult Gores technical department.. blah blah blah..don't sue me...
As for the spalling of the glass surface on the inner diameter of the vessels, I doubt it's a gasket issue unless bits of envelope gasket are falling off or some sort of particulate is forming in the crevice between the gasket and the flange face.. which is then somehow abrading the surfaces..but these are pretty wild guesses. De Dietrich's engineers are in a better position to help you here I think.
If your European colleagues want any help moving away from 20th century old school envelope gaskets to 21st century ePTFE tape, please point them towards us.
Dan
