Molecular weight of resin
Hay,
we are searching a simple method for measuring of resin molecular weight which may be used for fast quality control check. Which method do you suggest? It needs to be fast, easy and stabile. Thanx in advance!
RE: Molecular weight of resin
The usual QC method is doing an MFI (melt flow index measurement) but that doesn't really measure molecular weight. What it will do is tell you if the viscosity has changed and that will indicate if molecular weight has changed compared to your usual value.
Chris DeArmitt PhD FRSC
President
Plastic materials consultant to the Fortune 100
www.phantomplastics.com
