Warehouse Ventilation
Hi Guys,
I'm doing general warehouse design. As ASHRAE ACPH requirement is only o.o6ACPH/sqft.
But as its a large warehouse area of approx. 3500 sqm and height of 11mtr.
Im going with industrial fans.
So i'm installing industrial fans, there will not be any air change until the doors get openend.
Is this work to maintain comfort condition in area.
RE: Warehouse Ventilation
1) Make-up air fans
2) Louvers with dampers. Dampers can be either motorized or gravity.
Will it be comfortable, depends on your definition of what comfortable is. Will you be able to maintain 75F, 50% RH when it's 95F/80% RH outside, no.
Whether or not basic ventilation will be enough will depend on what is being stored in the warehouse and the number of occupants. This is something you need to discuss with the owner to establish what his requirements are, then design a system to meet his requirements.
The area is already having louvers on wall on all 3 sides.
