Tube Buckling
Tube Buckling
Hello all and thanks in advance here,
I've got a Shell & Tube Heat exchanger with 4 3/4" thick tubesheets. (Stationary and Floating)
It's a Tema type AES exchanger -- 61" I.D. shell and channel with (2544) 3/4" o.d. Tubes on a 1" 45 degr. rotated sq. pitch.
It's all carbon steel, SA-516-70N except for the 410 S.Stl. Baffles. The tubes are welded SA-214 c.steel, Roller expanded only into the thubesheet.
It has a 5/16" corrosion allowance on the tubeside and runs at 308 psi @ 650 Degrees F. on the shellside and 308 psig @ 650 deg. F. on the tubeside.
My problem is the tubes are overstressed and I have no idea what are where to beef this thing up to eliminate the problem.
I apologize in advance for the length post, but all help is appreciate.
JW
JW
RE: Tube Buckling
RE: Tube Buckling
RE: Tube Buckling
The exchanger service is " DE-ETHANIZER REBOILER"
The MAWP (shellside) is 308 psi @ 650 with a -20 MDMT @ 308 psi.
The MAWP (tubeside) is 190 psi @ 650 with a -20 MDMT @ 190 psi.
RE: Tube Buckling
Is the unit clean? Do operating conditions cycle a lot?
RE: Tube Buckling
Tube buckling could be occuring on the heating medium side if steam condensate has some level on the shellside for example on a horizontal kettle. Give us a process description and process control details else you'll have many of us stabbing in the dark.
RE: Tube Buckling
Or it does not float enough, if the unit is rapidly heated the tubes may expand enough to buckle before the head moves enough to relieve the stress.
RE: Tube Buckling
Another option would be to switch the baffle arrangement to a "No Tubes In Windows" design since NTIW baffles allow for intermediary support baffles, so you can dramatically reduce the unsupported tube length.
Both of these will help prevent tube buckling.
-Christine.
