Q about Fire Hose Cabinet Requirement.
Hi! Good day to all. As the subject implies, I want to ask if there is calculation for firepump capacity based on fire hose cabinet only? I am searching here but only I found sprinkler systems in involved.
We have a renovation project and this house is only using 5 fire hose cabinet with no sprinkler system. I want to check if the existing firepump and jockey pump is enough for this said project. Thanks!appriciate your time
RE: Q about Fire Hose Cabinet Requirement.
Thank you sir, any calculation needed for that sir? I mean, riser sizes and branches??
