Product Outline (TC)
I am writing a thesis on handling of large assemblies in NX. I would like to know where I can get the following information about the feature_product outline:
Product Outline: How can be changes supplied in NX? With Teamcenter-connections: what must be checked (probably filebased is saving everything)
You can see the PO in TC? Where is stored the PO? In the Assembly PRT or in an additional File? If it is stored in the Assembly-PTR, how does it change the file size?
How it behaves with changes to the individually loaded single part? (NX/ is there a display in TC?), how is PO updated? How do I work with links? As with Arrangements / deformable parts / reference sets?
Is it possible to build hierarchical POs? And how is the update behavior?
I hope on some information to where I can find something to read or get tips. Thanks
RE: Product Outline (TC)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
